Just wanted to clear something up. I have a 2010 dodge on the way so I called your office and they confirmed that the 1040 will work. I received the epp and noticed that it has 2 sets of connections. Why would it have two sets if does not do boost fooling. I would assume you do not plug it into the MAP sensor and only plug into the fuel pressure sensor. Do you just leave the connections for the MAP sensor unplugged? Also how do you use a quad boost fooler with this.
THANX
DARCY
2010 dodge
RE: 2010 dodge
you would need a map sensor hooked up to it to give it map readings to adjust the fuel off of. I am pretty sure you can add the boost fooler with the puck.
It makes sense to not fool the puck so I would plug the puck onto the senor of the vehicle, then plug the opposite connector into the input of the fooler and then plug the output of the fooler into the harness connector. That should work but I am not sure for that setup. couldnt hurt to try. tech support will probably be gone until monday morning. that is why I am throwing out my best advice.
RE: 2010 dodge
In the instructions it does not say anything about pluging into the MAp sensor. Is there just an extra set of plug ends or do I have the wrong harness? Any help greatly appreciated.
RE: 2010 dodge
Also does this product do boost fooling or will I need to order a boost fooler. I have heard and read that it does and does not.
RE: 2010 dodge
It looks like you got the wrong harness or wrong part number.
There should not be a MAP connection on the P1040.
See if the retailer can swap it out for you, if not, we'll take care of it.
Did you get the shim kit with it?
RE: 2010 dodge
on the box it states that it is P1040 but is there any way to check the puck itself. I did get the shim kit with it.
RE: 2010 dodge
best bet would be to swap the whole unit out to be sure.
RE: 2010 dodge
sorry, I was totally off on the harness issue. Thanks for clarifying everything mike.
