I have a Predator, married to my 2007 Z06 Corvette. This morning I tried to monitor data on a friend's 2007 Z06 and after it booted up and as I tried to go to diagnostics, his engine died and would not restart. We tried several times, Predator hooked up and not hooked up. Dead. Would not engage starter. We finally disconnected the battery and after connecting it back, the car acted normal, started and ran fine.
We did not attempt to hook up the Predator again. Now I'm concerned to hook it back up to my car! What should I do?
Problem with Predator
RE: Problem with Predator
Did the Predator display any error messages as it tried to communicate with the other car?
That should not have been an issue.
If you would like you can have the tool checked out under warranty by filling out the RMA request form in the dowloads page of this website.
Westx07zo6
Re: Problem with Predator
I'm confused here.. so you have a Predator married to your Z., and then you connected it to a differiant car?abqz06 wrote:I have a Predator, married to my 2007 Z06 Corvette. This morning I tried to monitor data on a friend's 2007 Z06 and after it booted up and as I tried to go to diagnostics, his engine died and would not restart. We tried several times, Predator hooked up and not hooked up. Dead. Would not engage starter. We finally disconnected the battery and after connecting it back, the car acted normal, started and ran fine.
You can use the tool to datalog or clear codes on other supported vehicles, but not to tune other vehicles.Westx07zo6 wrote:I'm confused here.. so you have a Predator married to your Z., and then you connected it to a differiant car?abqz06 wrote:I have a Predator, married to my 2007 Z06 Corvette. This morning I tried to monitor data on a friend's 2007 Z06 and after it booted up and as I tried to go to diagnostics, his engine died and would not restart. We tried several times, Predator hooked up and not hooked up. Dead. Would not engage starter. We finally disconnected the battery and after connecting it back, the car acted normal, started and ran fine.
We did not attempt to hook up the Predator again. Now I'm concerned to hook it back up to my car! What should I do?The manual says not to do that correct
