How to access 91 tune u7198 and disable skip shift
Posted: Thu Feb 18, 2010 5:24 am
by ls1owner4life
I have a u7198 and just updated the latest software. However, I could not find an option for a 91 octane tune (CA). The options I saw were Performance tune and Factory HP tune. How do I access a 91 octane tune and second how do I disable skip shift (02 ls1 Camaro) Thank you!
RE: How to access 91 tune u7198 and disable skip shift
Posted: Thu Feb 18, 2010 6:00 am
by yotadog2000
the 91 octane tune is the diablosport performance tune. On some programmers they dont actually say 91 next to performance tune
Posted: Thu Feb 18, 2010 9:12 am
for skip-shift... it's CAG's...
hook up to your car... select the same diablo tune you installed before, then go to Modify Tune... go to CAGs... highlight OFF, press the center button to save your selection... then press the ESC button a few times until it asks you "Install tune now?"
answer/select YES and it will install the diablo tune to your car with the cags adjustment you made.
Posted: Fri Feb 19, 2010 7:18 am
by ls1owner4life
confused... I was informed that the performance tune was a 93 octane tune.
Posted: Sat Feb 20, 2010 1:08 am
by concoursd
yeah the diablosport tune is safe for 91 and 93 octane also known as premium fuel. For people with 93 octane tune they can add a couple degrees of timing (10% advance) to the performance tune. otherwise they will just use the tune as is if they have 91 octane in the tank.
monte is right that you should see CAGS as an option in the modify tune area of the predator.
Re: RE: How to access 91 tune u7198 and disable skip shift
Posted: Sun Feb 21, 2010 12:50 pm
by flynnaz
concoursd wrote:yeah the diablosport tune is safe for 91 and 93 octane also known as premium fuel. For people with 93 octane tune they can add a couple degrees of timing (10% advance) to the performance tune. otherwise they will just use the tune as is if they have 91 octane in the tank.
I thought the Diablo tune was for 93oct? I have 91oct where I live, and I am running the 91oct tune. Would I see any benefits switching to the Diablo Tune?
Posted: Mon Feb 22, 2010 5:22 am
by ls1owner4life
where did you find this 91oct tune? Mine only has performance or factory HP.
RE: Re: RE: How to access 91 tune u7198 and disable skip shi
Posted: Mon Feb 22, 2010 9:50 am
by flynnaz
I think you pick performance, then within that you picl between the two for a Manual trans.
Posted: Mon Feb 22, 2010 1:50 pm
by concoursd
The predator has different tune options depending on the application and software revision installed. Some will show factory hp, 87 octane, and diablosport performance tune. Some will say factory hp and 87 octane, 91 octane, and 93 octane.
It is kind of confusing.
If your predator only has three tune options (factory hp, 87 octane, and diablosport performance) then you can use the performance tune for either 91 octane or 93 octane but you must run a minimum of 91 octane. you can add some timing advance if running 93 octane fuel but you need to dial it back if you hear pinging.
If you dont see an 87 octane fuel tune in a GM gas predator then you should run a minimum of 91 octane fuel.
Posted: Mon Feb 22, 2010 8:28 pm
by flynnaz
So my question is, Is the Diablo Tune safe for a engine using 91 oct?
Posted: Mon Feb 22, 2010 11:10 pm
if you only have 91 octane gas where you live, then only use the 91 octane tune...
the diablo tune, for 93 octane gas, has higher timing/more spark advance for higher octane fuel... so if you run that tune on only 91 octane gas, you'll get knock...
Posted: Mon Feb 22, 2010 11:14 pm
by flynnaz
Thank you :)
Re: RE: Re: RE: How to access 91 tune u7198 and disable skip
Posted: Sun Feb 28, 2010 7:38 am
by ls1owner4life
06MonteSS wrote:if you only have 91 octane gas where you live, then only use the 91 octane tune...
I still can not find this "91 octane tune" after I updated the predator.
RE: Re: RE: Re: RE: How to access 91 tune u7198 and disable
Posted: Sun Feb 28, 2010 7:51 am
and you won't....
cuz it's just called "Performance Tune" or "Diablo Tune" on yours...
it doesn't say the actual number "91" next to it, as was mentioned in the 2nd post up top...
