Revision Update Instructions docs - 404 not found error...
Just noticed you posted Revision Update Instructions on the U7191 download page... problem is, when you click on either link you get a 404 Not Found error. Either the document isn't actually up in the downloads folder, or try removing the spaces from the filename.
Just wanted to give you guys a heads up...
RE: Revision Update Instructions docs - 404 not found error.
thanks...
right click, save target as....
nope, that doesn't work... they need to remove the spaces from the filenames, or use underscores like the did for the others...
I'm a web developer, so I've run into this issue before... ;)
actually, I just checked the path - and they have the path to the documents wrong...
they have it coded to go here:
http://www.diablosport.com/downloads/Revision update instructions.doc
but it should be this: http://www.diablosport.com/downloads/pr ... ctions.doc
they currently don't have it pointing to the /predator/ subfolder....
...ttt...
He is fixing it in the next few minutes....
Return to “Predator Ford Gas”
