U7198
Hardy350
U7198
Post by Hardy350 »
Hi All,
I bought a used U7198 it is posible to reprogramm the Pretator to the delivery status ?
Regards
Hardy
RE: U7198
huh?? you mean reset it like it was brand new??
is it still locked to the previous owners vehicle??
if it is, then you'll need to call up diablo tech support... and depending on what revision it is on - if it's on a newer 9rXX revision, it'll cost you $129 to get it unlocked... if it's on an older 1.xx or 2.xx revision, you'll need to send it in to diablosport and pay $149 to get it unlocked and upgraded to the newer version 7198...
Hardy350
Post by Hardy350 »
Yes it is Vin locked to a 03 Corvette.
So can I unlock my U7198 online?
Hardy
scottvancil
Post by scottvancil »
Hey 06MonteSS,
On my 7198, the new version, is there a way to change the vehicle speed from KPH to MPH? I have looked all through the programmer and cant find where to change it, even if i can change it. I appreciate all your help.
you mean on the screen while your data logging/monitoring??? no...
but when you export the data log from the predator to your pc using the Dataviewer, the speed will be in correct mph...
concoursd
Post by concoursd »
Hardy,
You need to contact diablosport tech support at 800-531-5484 and pay $129 to have it unlocked over the phone.
