Battery terminal removal good or bad?
I bought my predator 7194 and installed on the truck (08 silverado) and now I want to lift the truck. There is a little bit of welding in installing the lift so I was gonna unhook the battery. If I unhook the battery will I lose the predator settngs? Should I set back to stock and then unhook battery or what is recommended?
- Ill_Born_SS
RE: Battery terminal removal good or bad?
Yes go ahead and disconnect all your parameters will remain, but it will clear the memory in the pcm/ecm and the normal re-learn will happen afterwards. The transmission will also require a re-learn if the battery is disconnected for longer than 20 min. as it will also loose its memory and relearn afterwards also.
So for the first 75-100 miles drive it normal for the re-learn then giver!
" Just Friggin Wicked"
Now with TCM support...
yep, no worries... you will not lose the tune in your truck...
like Ill_Born said.. only the learned items, like fuel trims, emissions readiness tests, etc etc will get reset - which is normal... those are relearned by the ECM and will settle back in after about 100 miles are put on...
