09 Silverado 5.3 WOT Parameter Adjusting
Posted: Fri Feb 19, 2010 7:58 pm
by dbroylz
I have an 09 Silverado with the 5.3 "0" engine. I am using the U7194 v.9r13. When I look at my WOT log in DSLogRedux it gives me 2 adjustments for 2 rpm ranges. I have 3 rpm ranges in my tuner. What do I do? My LTFT's are dialed in at -.78 and -1.56. I attached my log. Any help will be appreciated. DSLogredux tells me to adjust -5 for <3999 and -6 for >4000. When I go to modufy parameters it gives me 2k-3.8k, 4k-4.9k, and 5k-7k.
RE: 09 Silverado 5.3 WOT Parameter Adjusting
Posted: Sat Feb 20, 2010 1:11 am
by concoursd
you need to go into your injector slope setting and add 2%. Then you need to go to the 2k-3.8k WOT PE setting and adjust -5 and then go the 4k-4.9k and 5k-7k ranges WOT PE ranges and enter in -6 in each.
Posted: Sun Feb 21, 2010 10:20 am
by tdub09
dbroylz PM me and let me have your email i have somethn you would like! haha
Posted: Wed Mar 03, 2010 3:51 pm
by stonedogg
i have a 05 silverado 5.3 no cats cold air induction throttle body spacer 410 rear end just wondering what i need to set my programmer on i have the preadtor
Posted: Wed Mar 03, 2010 4:07 pm
by 06MonteSS
check your data/ltft and adjust your injector slope so that you get your average ltft's in the 0 to -2 range...
Posted: Wed Mar 03, 2010 8:56 pm
by dbroylz
Thanks for the help. I have my ltft's dialed in and made PE fuel adjustments per DSLogRedux. Now it tells me no adjustments necessary so I must've done it right. Does anyone know when the 3 rpm DSLogRedux will be out?
Posted: Wed Mar 03, 2010 9:47 pm
by 06MonteSS
not sure... I haven't heard from GrumpyAeroGuy in a while... he may be away on business.... will have to see where he is with it...
I'll shoot him an email with a link to this thread...
