Predator U7155
predator v.9r03
ford f250 v-10 lariat
I just got my predator back from you guys for warranty work to unlock and update my predator. I plugged it into my truck to install a tune to it and I get an error. Reads as follows. Your vehicle is not in our database. Contact your dealer for a free update. Your CAL_ID is 'TDFG8P2'.
I then press continue and it brings me back to the main menu.
EDIT: It used to work with the 9r02 revision...I don't know if I can go back to that revision or not. I have downloaded the DSDownloader and the 9r03 revision and tried reloading it into the tuner. The tuner successfully takes the update but I get the same error when I try to tune my truck.
Cannot write any tune into 08 f-250
frazman187
RE: Cannot write any tune into 08 f-250
Any ideas?
o rly? Hmmm you are on 9r03 now? I will look to see if your cal id is supported or not in that new 1.
Don
2002 WS6
2002 WS6
frazman187
frazman187
Can I get the 9r02 file back and just use that until this issue is resolved with 9r03?
frazman187
Any updates for Cal_ID TDFG8P2 yet?
