Is there a tune for 89 octane with a cai? I tried searching for 89 tune and couldn't see anything, so I thought I would just ask.
Thanks,
NCGrimbo
89 Tune?
RE: 89 Tune?
No, use the 87 tune (and save a few cents and run the 87 octane fuel too)
RE: 89 Tune?
Where can this 87 tune be had? I have a knock (about 10° knock retartd) at part throtle even with the best fuel I can get where I live.mikel wrote:No, use the 87 tune (and save a few cents and run the 87 octane fuel too)
2007 300C SRT8, DS Pred, 180 stat, BT catch can.
1997 Camaro SS, L98 Gen IV transplant, T56, Moser 12 bolt, HPtuners.
RE: 89 Tune?
there is no 87 octane tune for the 300 SRT-8... since you should be running at least 91 octane in that anyway...
you only have the options for a 91 octane tune, or a 93 octane tune...
Re: RE: 89 Tune?
I would check for oil build-up in your intake manifold as this is the primary and most common cause of spark knock with the hemi engines. If there is buildup/puddle of oil then clean it up and get catch can to catch the oil before it gets sucked into the manifold.sssalah wrote:Where can this 87 tune be had? I have a knock (about 10° knock retartd) at part throtle even with the best fuel I can get where I live.mikel wrote:No, use the 87 tune (and save a few cents and run the 87 octane fuel too)
RE: Re: RE: 89 Tune?
I run 89 exclusively w/ ACES IV fuel additive (it is NOT an octane boost...it IS a fuel catalyst), and got a custom tune for 89 octane......runs like high octane. Well worth the effort.
'13 R/T Charger w/ STP: DS catch can / Mopar CAI / SRT headers & mid pipes
