Just received U7180 (v9R08) to program lb7. Made sure fuses as indicated were pulled and no other added accessories powered up. saved factory tune.(as far as i know factory tune as I just bought the truck, previous owner was using EFI live but said he returned to stock) when I go to the performance tune section no tunes are listed. When I go to adjust tire size on factory tune, it says unsupported. This truck has the suncoast 6speed conversion in it, would this be causing the problem? any help would be appreciated.
I have attached saved tune if this helps.
2003 lb7 can't install tune or adjust tire size
2003 chev Silverado 2500 HD Duramax
Suncoast 6 speed conversion
RE: 2003 lb7 can
You need to go to diagnostics and then go to show calid. write down and post all of the names and numbers. This will let us know what GM software version you have installed.
Some really old GM software versions are unsupported. This rarely happens and can be resolved by having the local dealer or independent shop reprogram your truck with a newer version of the GM software that was sometimes added for warranty purposes to resolve complaints.
RE: 2003 lb7 can
OK so here are the numbers from calid, what does this tell you?
ecm software 03904401V1
engcal 15189052AD
engdiagcal 15076379BH
fuelcal 15076353AP
vehsyscal 15076385BL
vehspeedcal 15076392AN
engcal 15189052AD
fuelcal 15076353AP
RE: 2003 lb7 can
doesnt tell me anything. I asked you to post it so the diablosport can look at why your truck's software is not supported in the current software of the predator. Since they work Monday - Friday, they would end up asking you for the same information I just did so now you are ahead of the game.
RE: 2003 lb7 can
thanks for the info - hopefully I can get this going by next weekend.
RE: 2003 lb7 can
has anyone had a chance to look at my software versions on truck ecm to be able to tell me what the issue is?
RE: 2003 lb7 can
OK, per phone call here is my vin#
1GCHK29113E267451
1GCHK29113E267451
- Vas@Diablosport
RE: 2003 lb7 can
ok, i went ahead and sent all of your info to engineering. so im just waiting on a new update from them.
No, i don't work here.
RE: 2003 lb7 can
when can I expect the update to be available - it has been 3 weeks - has engineering even looked at this yet?Vas@Diablosport wrote:ok, i went ahead and sent all of your info to engineering. so im just waiting on a new update from them.
RE: 2003 lb7 can
So all my info was sent to engineering on March 3. That was 2 months ago. How much longer do I have to wait for this to be updated.
This is money out of my pocket for a product that does not work, and expect the least you could do is reply back on this forum that you are actually looking after your customers. If no reply, I will be joining every diesel forum I can find in the near future to let everyone know how your company does not look after its customers.
