Logging Parameters locations in sub-menus
aviraled2002
Post by aviraled2002 »
In the Trinity and new revision 7194 Predators, the logging/monitoring parameter listings are now all under different sub-menus.
This guide below can be used to locate the necessary parameters needed to log for a custom tune...
Air Fuel Ratio (Equivalence Ratio) = Under FUEL menu
Long Term fuel trim bank 1 = under FUEL menu
Long Term Fuel Trim Bank 2 = under FUEL menu
Spark Advance = under IGNITION menu
Intake air Temp = under INTAKE menu
MAF Sensor Mass Air Flow = under INTAKE menu
Total Knock Spark Retard =under MISFIRE menu
Engine Speed (RPM) = under PERFORMANCE menu
Commanded Throttle position (or Absolute Throttle Position - for older vehicles that don't have the Commanded parameter) = under THROTTLE menu
RE: Logging Parameters locations in sub-menus
NICE!! thanks man!!!!
woohoo!!!
this will make it SOOOO much easier for Predator/Trinity users now that they'll be able to find all the parameters and not have to search for hours... :lol:
aviraled2002
no..........Thank you Lew for everything. I know this will take some headaches from you...
Speeddemon
Post by Speeddemon »
aviraled, your a saint. :mrgreen:
"The Speed Demon"
aviraled2002
Awww...glad it helped!
ODB720
Post by ODB720 »
Nice had to save ' will save me a lot of headache. Thanks
2010 SS/RS COLD AIR INDUCTIONS CAI, PREDATOR U7194, 160 STAT,MSD WIRES,BILLET ACC. CAPS,
ARH 1/78 LONG TUBE HEADERS W/ CATTED X-PIPE AND SLP AXLE BACK
cwsmit
Post by cwsmit »
you just saved me about an hour. THANKS!
BONE STOCK (so far)
2010 SIlverado Reg. Cab Long Box
Floor Shift 4x4, 3.42's
4.8 V8
U7194 9r16
I WANT TCM CONTROL!
