I have been asked this alot and here is breakdown on what I like to see as far as pids go in order to properly adjust a calibration.
I split it up in the two different groups for 05-06 and then 07-up and they are grouped by the groups they are listed in Predator/Trinty and Dataviewer.
Dashboards are attached for Dataviewer as well.
2005-2006 PIDS
EPDSS
RPM
rpm
Foundation Inputs
MPH
mph
Charge Temperature
ACT
F
Coolant Temperature
ECT
F
Desired Fuel Air
OPEN LOOP FA
FAR
Fuel Flows
1/1 Short Term ADAP
2/1 Short Term ADAP
1/1 Long Term ADAP
2/1 Long Term ADAP
BARO
kPa
PRATIO
PRatio
Injector Control
TOTAL WORKING PW CYL1
us
Knock Control
KNK LT RETARD
deg
KNK ST RETARD
deg
Spark
ACTUAL SPK CYL1
deg
BASE SPK
deg
MAP
SENSED MAP
kPa
MAP TO USE
kPa
READ MAP KPA
kPa
Miscellaneous
RAW TPS1
V
RAW TPS2
V
2007-up PIDS
Igntion
Base Spark
Deg
Actual Spark Cyl 1
Deg
Intake
Intake Air Temp Deg
F
Manifold Air Pressure
kPa
Barometric Pressure
in Hg
Injector Pulse Width Cylinder 1
us
Fuel
REQD FUEL CHARGE CYL1
mg/charge
Miscellaneous
1/1 Short Term ADAP
2/1 Short Term ADAP
2/1 Long Term ADAP
1/1 Long Term ADAP
DESIRED FA CYL1
FAR
OPEN LOOP FA
FAR
READ MAP KPA
kPa
P-Ratio MAP/BARO
PRatio
Misfire
KNK LT RETARD
deg
KNK ST RETARD
Deg
Performance
Vehicle Speed
mph
Engine Speed
rpm
Read Engine RPM
rpm
Throttle
Throttle Position Sensor Percent
Accelerator Pedal Position
Throttle Blade Position
Good pids to log for your tuner...
- DCX_05_06.zip
- (637 Bytes) Downloaded 1206 times
- DCX_07_UP.zip
- (642 Bytes) Downloaded 1445 times
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
searles_400
best bet is to contact a CMR dealer for help....
I can't seem to find "DESIRED FA CYL1" under Miscellaneous in the Menu Map:
http://www.diablosport.com/beta/Predato ... enuMap.pdf
Is the original post outdated or perhaps the PDF?
- Dave
- Dave
