How much timing to remove?
Posted: Mon Jun 25, 2007 3:58 am
Running a 98 GT 2V with 12PSI Pro charger and 3 core inter cooler
Bassani X-pipe with cats
Borla Stinger cat back exhaust.
24 lb injectors
MAF calibrated by Pro-m for 24lb and pro charger
FMU
Always run 93 octane with octane boost and have a U7146 predator that was used on my 2003 GT.
No longer programmed for the 2003 GT and wish to use on the 98 However I need some one to tell me exactly how much timing the diablo tune installs so that I can REMOVE that amount immediately after installing the tune?
I am thinking the number to remove is 2 degrees? could someone officially tell me the amount? I want to make sure the tune does not add timing until the car gets on the dyno later this year.
A/F ratios are not a concern as wide band o2 sensor installed.
Also need to know if custom tune will compensate for larger injectors without the need to recalibrate my MAF? Other companies can do this? need to install 42 lb injectors to handle the pile of parts that are going to be installed shortly but PRO-M is no longer in business so sending my stock meter out is no longer an option.
24 lb injectors
FMU
