Tried installing V9r14 to u7194 and get error Please Help
6.0psracer
Post by 6.0psracer »
Recently, we had a truck that went into the shop and when it came back we couldn't reinstall the tuner. So i tried to update to the most current revision on the tuner 9r14. The previous version I had installed was 9r05a. the error i get says
"CROM u7194-v9r14. Incompatible hardware(No serial flash found)"
The vehicle it was in was a 2007 GMC 2500HD with a 6.0L motor New body style.
Can you please help?
soooo, this was actually on a Predator, not a Trinity... (you posted this in the Trinity forums, heh)...
that's an older hardware model 7194 Predator, it will not take/accept the newer, bigger revision update files...
the highest revision you can go up to on that is 9r08, and MAYbe 9r10....
I've attached the 9r08 revision update for ya... try that...
u7194-9r08.crom
(889.08 KiB) Downloaded 184 times
6.0psracer
Yeah, I realized after I posted that I was in the Trinity forum instead of the Predator. I installed the 9r08 on the Predator and it will boot now. I have to try it on the truck tomorrow. Hopefully it will work.
nice!!
Return to “Trinity GM Gas”
