2006 chevy 5.3 parameters
Bigd8907
Post by Bigd8907 »
I have a 2006 chevy silverado with 5.3. I have a k&n 77 series cold air intake. Diablo predator tuner u7192. Single in single out super 44 with turndown. Leveling shackles. It is a 2x4. I currently have the tuner set on diablo tune. I was just wondering what are the best custom tuning setting for the parameters would be. For the best performance. I know it gives options for custom tuning. And if anybody has any good suggestions for my next step for more power. I'm always interested in hearing ideas. Thanks
Bigd8907
RE: 2006 chevy 5.3 parameters
Post by Bigd8907 »
I was also wondering about the data logs. How do u do the data logs. I'm completly new to the tuning world. Sry for asking the basic questions everybody should already know. And how do I upload the tune settings to email them in.
2006 chevy silverado 5.3 2x4 ext cab
diablo predator (diablotune)
77 series k&n cold air intake
super 44 flowmaster
2" lowering shackles
the "custom tune" you see in the predator is to import and install a custom tune file that you'd get from a diablosport CMR custom tuner, like myself. If you're interested in getting a custom tune, you can check my info here:
http://www.dslogredux.com/DiabLew_Tune/
do you have the newer version 7192 on a 9rxx revision so you can record/save data logs??
as for logging and getting your fueling dialed in, see here:
Bigd8907
Post by Bigd8907 »
Ok man thanks for the info. Just wondering if the custom tune wld really get me better results than the diablo tune preset. Which I do plan on adding a cam later on.
super 44 flowmaster
Bigd8907
Post by Bigd8907 »
I have the newer version. It's a brand new tuner just got it. I'm currently running diablotune. I turned off torque management. I didn't alter any shift points or anything like that.
super 44 flowmaster
do some data logging and get your fueling dialed in... you will get better throttle response, better acceleration, stronger pull, and better mileage...
and yes, a custom tune would give you even more improvements...
coreystallings
Post by coreystallings »
GET THE DIABLEW TUNE FROM 06 MONTESS, IT IS WELL WORTH THE MONEY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
hahahaha!!!
thanks Corey...
