extreme power puck dial, how u use it?
Posted: Mon Mar 08, 2010 5:06 pm
by DieselSmoke
I stacked the Extreme Power Puck on my 06 Ram 2500 5.9 ctd with my Predator. The puck came with an installation manual only. Im not sure what hp im dialing. For instance, Im running the extreme stack setting, so, if the dial or knob is all the way to the left would that be off, and as I turn it to the right does it incrementally go in hp till its turned all the way to the right, wich would be 18o hp.??? Im clueless, can anyone help?
RE: extreme power puck dial, how u use it?
Posted: Mon Mar 08, 2010 5:31 pm
All the way to the right is plus +100rwhp, to the left is off....
Posted: Thu Mar 11, 2010 2:47 pm
by DieselSmoke
Ok, so how much hp would that be on a stack tune, such as extreme?
Posted: Thu Mar 11, 2010 3:11 pm
by DieselSmoke
For instance the add for the puck claims I can achieve 200rwhp stacking it with the predator. So on the most extreme stack, would I be dialing 0 to 200 rwhp? And would off be back to stock settings? I appreciate your assistance, Thanks!
Posted: Thu Mar 11, 2010 3:34 pm
Staking it will generally make more power than the stock fuel system will support, but yes, you could easily add the 100 HP tune, and dial the puck up another 100 HP, and be +200 rwhp...
Posted: Fri Mar 12, 2010 5:17 pm
by DieselSmoke
Sorry, that doesnt really answer my question. I know the most extreme stack will produce 200 hp, I wanted to know if the dial is off, will it be on the stock setting, while stacked. When the dial is off, does it just take off the power from the puck, and still getting gains from the predator, or am I back to stock setting?
Posted: Fri Mar 12, 2010 5:21 pm
by DieselSmoke
More impotantly whats the highest stack I can run and still be safe, with stock fuel system?
Posted: Wed Mar 17, 2010 6:44 pm
by DieselSmoke
Hey Mike, can you help me?
Posted: Wed Mar 17, 2010 7:46 pm
by concoursd
if the dial is all the way off then you will be only eliminating the pressure added from the puck. The puck dial does not affect any of the predator settings, so if the puck is stacked over the predator, then you will default to the currently installed predator tune as the only power adder. Then as you increase the dial on the puck, you will be increasing the puck's affect on the pressure on-the-fly.
Posted: Fri Mar 19, 2010 10:47 am
by DieselSmoke
Thanks.
