FLX7193 Worth the Money? 04 silverado 5.3
Hi, ive been looking at buying one of the FLX7193 programmers for my truck. But im not really sure its going to be worth the money for me. How much of a mileage drop will I see? Will there be a noticable hp gain? Can it mess anything up on the truck? Thanks alot
RE: FLX7193 Worth the Money? 04 silverado 5.3
unless you run E85 ALL THE TIME... it's not worth it man...
E85 by itself is a known culprit to having worse mileage...
Well ya if I bought the programmer I would run E85 all the time
The FLX7193 is designed to take a non flex-fuel truck and allow it to have full flex-fuel capabilites- meaning you can run gas or E85 at any time without flashing between fueling changes. Generally you will see about a 12-18% drop in mileage when using E85, but you will also see a gain of .5 to 1.5 when running gas on the SAME TUNE. This obviously depends greatly on driving habits- idle time, around town, and towing a trailer it WILL be worse. Analyze your COST PER MILE- if you are saving 30% per gallon when you fill ($2.70 per gallon vs $2.04 per gallon for e85 currently here) and lose 15% economy, it is a no-brainer. You can toggle between fuels any time although if you need to. All the performance enhancements are in the tunes (actually a few more) than the regualr 7193 tool as well. We have found no detrimental effects over time and I have multiple vehicles running these tunes now for 100k miles since the conversion (on these newer vehicles).
Andy
Andy
Re: RE: FLX7193 Worth the Money? 04 silverado 5.3
Thanks for dropping by Andy!!dynometer wrote:The FLX7193 is designed to take a non flex-fuel truck and allow it to have full flex-fuel capabilites- meaning you can run gas or E85 at any time without flashing between fueling changes. Generally you will see about a 12-18% drop in mileage when using E85, but you will also see a gain of .5 to 1.5 when running gas on the SAME TUNE. This obviously depends greatly on driving habits- idle time, around town, and towing a trailer it WILL be worse. Analyze your COST PER MILE- if you are saving 30% per gallon when you fill ($2.70 per gallon vs $2.04 per gallon for e85 currently here) and lose 15% economy, it is a no-brainer. You can toggle between fuels any time although if you need to. All the performance enhancements are in the tunes (actually a few more) than the regualr 7193 tool as well. We have found no detrimental effects over time and I have multiple vehicles running these tunes now for 100k miles since the conversion (on these newer vehicles).
Andy
RE: Re: RE: FLX7193 Worth the Money? 04 silverado 5.3
How much of a power increase can you get while using E85?
Re: RE: Re: RE: FLX7193 Worth the Money? 04 silverado 5.3
25-30 rwhp over stock...Tyler.C wrote:How much of a power increase can you get while using E85?
