Noob? U7193
jbeam
Noob? U7193
Post by jbeam »
Im new to this truck tune stuff so I have lots of questions. First I have an 04 silverado Z71 with 5.3 vinT. Does this unit do data logging and live monitoring? Do you need to do this to use the DSlogRedux? Im trying to do all the research on the unit so when I do get it I will not have so many questions later. But I'll still have alot of questions.
RE: Noob? U7193
yes, does data logging...
yes, need to do a data log to use DSLogRedux...
jbeam
Re: RE: Noob? U7193
Post by jbeam »
06MonteSS wrote:yes, does data logging...
Thanks 06Monte.
jrmybck
RE: Re: RE: Noob? U7193
Post by jrmybck »
how do i log dat. all i see is real time data. no logging...
Speeddemon
Post by Speeddemon »
Choose real time data and then watch and record.
"The Speed Demon"
what revision is your predator on??
if you have an older 2.xx revision predator, you can not save data logs... it has to be one of the new hardware models on a 9rXX revision...
then it would be under real time data, watch & record like speeddemon said...
jrmybck
Post by jrmybck »
it is 2.04 cant save it. how do i to a custom tune then? or do i
rmck490
Post by rmck490 »
I data log with a third party software and interface: Palmer Performance ScanXL Pro with the OBDLink interface. These logs can be exported to Excel in .csv format that can be used in DSLogRedux.
In your case, if you want to be able to save log files, I recommend you send it in for an upgrade. It would be cheaper than getting the same setup I have. The ScanXL w/OBDLink setup will cost you around $190 (I think). I haven't upgraded my tuner (yet) because I already had this setup and thus had the ability to work around the logging issue.
2000 Chevy Silverado 1500 Z71 4WD ECSB 5.3L
U7198 ver 9r17
Diablew Tuned
K&N CAI
Corvette Servo
