Bets Tune for me
Jakes340!
Bets Tune for me
Post by Jakes340! »
I have a 05 Rumble bee i was wondering after i select 93 oct. could anyone help me with the best custom tune's with the gas and spank and so fourth....i have a gibson exhaust ported throttle body aem intake and msd sparkplug wires if this will help
thanks jake
Jakes340!
RE: Bets Tune for me
Post by Jakes340! »
i want the most power i can get out of this
Animal451
Post by Animal451 »
If you run 93 octane gas then use the 93 CAI tune, if you use 91 (which Californians are limited too) use the 91 CAI tune. I wouldn't mess with the fuel unless yu have a widebank A/F gauge to see what you're WOT mixture is actualy at. You could go have a shop dyno the car but you'll have to have them putthe sensor in you're exhaust before the cats to get a true reading.
I had a shop dyno my car after similar mods (I already had a wideband) and my Innovate W/B showed my A/F at 13.5 at WOT. This is a bit lean so the shop verifyed my readings and I made the adjustments to add fuel to get down to 12.2 to 12.5.
Every car is a little different . . .
'06' SRT-8
Airaid CAI; 180 T-Stat, SpartanMAX, CMR Tune
JBA Catback; ESP Disable, SLP Linelock
Innovate LC-1, Wavetrac LSD
R1 Drilled/Slotted Rotors
bighemitex
Post by bighemitex »
if he has a rumble bee he doesn't have CAI tunes available and for the fueling at wot you can adjust it without a wideband, just monitor knock and add fuel to quench the knock out. i did that and it pulls really hard at WOT. i am using the 93 tune with 93 octane
Jakes340!
Post by Jakes340! »
right now i am using the 91 tune and messed with some of the rpm levels and added a little gas to it but didnt want to mess with the spark. i have a full tank of gas so when it gets low im going to get 93 and set that tune
