weird issue with new mod tm tunes
Posted: Tue Jun 26, 2007 10:52 pm
by duallydave
as soon as i read there was a tm modified tune a loaded it up pronto,all i have to say is wowowowow.its the bomb,i loved the response and the power and it didnt smoke as much as i thought it would,awsome tune,but im having a weird issue with it,in second gear{manual}as soon as i touch the throttle it revs to 1100 rpms and stays there till i let the clutch out,kinda freaked me out the first time.does it pretty steady in second and somtimes 3rd.never in the higher gears,rpms just hang there,weird,i couldnt drive like that in town so i loaded another tune from that set and same thing so i loaded the factory extreme tune and all is well, ok not so well,the factory extreme feels like going from extreme to stock,i got used to the new tm tune and hope to ger her back in,any sugestions?i just did the high idle mod for it with the cummins part that grounds pin #22 on the ecm,could this be causing it?i disconected it when i got home and ill try loading the tune and try agaon tomorow. sorry for the long post once again love the new tuneeeeee
RE: weird issue with new mod tm tunes
Posted: Wed Jun 27, 2007 8:03 am
by modified03
I had some high rpms after I loaded the new tune also. Mine would stay reved up and never come down till I actually took off and when I tapped the pedal it would climb higher? I really wasn't impressed with the smoke either I think the rkl or even extreme smokes better then it. But it did produce some awsome downlow power i'll give it that.
Posted: Wed Jun 27, 2007 8:07 am
by johan
He he, i had the same thing happen to mine when i jacked the values up too much. What calids are you guys using and i have to tone it down a little.
Best thing to do would be if you e-mailed me and i will e-mail you test tunes until we get that issue sorted out then i will post them back up for download.
Shoot me an e-mail with your calid.
