U7135 91 tune 89 oct gas
for one of the DSP guys. Can I run 91 tune on 89 oct 06 300c
RE: U7135 91 tune 89 oct gas
Nope. not a good idea.
Red_Rocket
2008 300c 5.7 89 octane tune?
Can the 91 octane tune (U7135) be modified to use 89 octane fuel? I read that it would work if the timing was retarded by 2 deg.
Any plans for 89 octane tune in the future?
Thanx
Thanx
RE: 2008 300c 5.7 89 octane tune?
No, we do not do 89 octane tunes for performance cars, just does not make sense.
Re: 2008 300c 5.7 89 octane tune?
While DS may not make an 89 octane tune, they have given instruction on how you can modify the 91 octane tune, yourself, so you can run 89 octane gas:Red_Rocket wrote:Can the 91 octane tune (U7135) be modified to use 89 octane fuel? I read that it would work if the timing was retarded by 2 deg.
Thanx
http://www.diablosport.com/index.php?na ... pic&t=3712
also see item #17 here:
http://www.case-enterprises.com/xeryder ... edator.htm
RE: Re: 2008 300c 5.7 89 octane tune?
Thank you Ill check it out
- Doc_Whisky
If you run ACES IV in your vehicle you can use 89 octane. http://www.bndautomotive.com/page/page/931760.htm
2009 Charger R/T, K&N CAI, ACES IV, 91 Octane + CAI tune.
Red_Rocket
89 octane tune?
Thanks. Where I live, 93 octane is expensive and rare.
Gekko wrote:While DS may not make an 89 octane tune, they have given instruction on how you can modify the 91 octane tune, yourself, so you can run 89 octane gas:Red_Rocket wrote:Can the 91 octane tune (U7135) be modified to use 89 octane fuel? I read that it would work if the timing was retarded by 2 deg.
Thanx
Red_Rocket
89 octane tune?
Thanx
Red_Rocket
89 octane tune?
Thanx
