Convert MAP OBD-II Into a Boost figure
SRTorRed6sp
I'm using a synthesized boost gauge and want to be able to convert the MAP reading in a log to a PSI figure. If it shows 22.19 what would that be in PSI of boost?
RE: Convert MAP OBD-II Into a Boost figure
I think you take the MAP and subtract atmospheric pressure (14.7psi) to get boost pressure. So 22.19-14.7=7.49psi of boost, or slightly more then 0.5bar (1 bar= 14.5psi).
SRTorRed6sp
That would put me real close to what I should have and makes sense. Thanks.
the synthesized pid is simply MAP minus baro.
Log both of them and you'll see...
