Has anyone tried this......
I was messing around with the predator and came across some options like: turn off ESP, automatic autoshift upshifting, and smoothness of shifting. Well I turned them on and when I finished installing everything all the lights in the dashboard lights up, all off them. The car was kinda slow too. So I had to uninstall everything and put the tune in again. Has anyone encountered this, how do I use these features? I called tech support and was told to disconnect the battery then connect again. I did, it didnt work. Any Ideas?
I have U7136 for 2010 chally
Turn off ESP with Diablo Predator
RE: Turn off ESP with Diablo Predator
With ESP off, the dash will always light up like a Christmas tree. Thats because it also disables Traction control, ABS, EBD and whatever else, and those are the warning lights. The disable is now called Dyno Mode, and is recommened only to be used on the dyno.
Turn it back on and the lights should go out.
