Downloader not responding after power cycle message, Win7
Questions and comments specific to the DiabloSport Downloader application.
ronnycordova
Post by ronnycordova »
I just received my tuner and currently am trying to update to the u7193-9r08 version. I can connect to the tool fine but anytime I try to send the update file I get the message to power cycle the tool and the program instantly goes non-responsive and locks up. I've tried leaving the tool off until I get to the reboot screen with the same results. Anyone have any ideas as to why it keeps hard locking for me?
Here is the tool info:
Auto Connect is ENABLED.
Legacy Connect is DISABLED.
A tool was found on COM3 at 115200 baud.
XML RPC commands are AVAILABLE.
XML RPC protocol version is 1.60
Tool type = 'Predator'.
Serial number = '218137438'.
Part number = 'slp7199'.
CROM version = 'slp7199-9r02 02/11/2010 11:39:57 AM boot4'.
Vehicle VIN = ''.
Vehicle Calibration = ''.
Origional backup NOT saved.
Tool is Married FALSE.
Single user tool FALSE.
Using Class2 Protocol FALSE.
Calibration Updates are NOT supported.
A Calibration Update is NOT required.
XML RPC WILL be used for FRG transfers.
Tune compression is AUTOMATIC.
Tune compression is set to ENABLED.
Tool registration is NOT supported.
Tool does NOT support multiple ECUs.
Config does NOT indicate multiple ECUs.
Tool reports 1 ECUs.
jimb
RE: Downloader not responding after power cycle message, Win
Post by jimb »
What version of DSDownloader are you using? 2.2.1.4?
Are your removing the power from Predator (unplugging the connector on top and reinserting?).
I notice your Predator has slp7199 and your trying to change it to u7193-9r08.
Return to “DS Downloader”
