need help johan
Posted: Thu Jun 28, 2007 1:25 pm
by Blue2003
just downloaded the v.8r28. it is the group in the sticky thats says post r28 i believe. went out to the truck downloaded the rkl exe.drd and when i finish waiting on the process went to start the truck it idled fine, tapped the go pedal and the rpm shot up to 2100 and would not idle back down. what has happend? do the other three programs do that? i wanted this set of programs because i needed no timing and wanted the puffer tune. does any of these programs like the one i have downloaded or the puffer have timing added? does this set of tunes require the puck use? i am running the TST without adjustable timing that is why i needed no timing.
RE: need help johan
Posted: Thu Jun 28, 2007 2:47 pm
by duallydave
the stacker tunes will be labeled stacker and they have iether less timing or no timing,and some of the rkl tunes will state less timing.
Re: need help johan
Posted: Thu Jun 28, 2007 2:52 pm
Blue2003 wrote:just downloaded the v.8r28. it is the group in the sticky thats says post r28 i believe. went out to the truck downloaded the rkl exe.drd and when i finish waiting on the process went to start the truck it idled fine, tapped the go pedal and the rpm shot up to 2100 and would not idle back down. what has happend? do the other three programs do that? i wanted this set of programs because i needed no timing and wanted the puffer tune. does any of these programs like the one i have downloaded or the puffer have timing added? does this set of tunes require the puck use? i am running the TST without adjustable timing that is why i needed no timing.
Johan has isolated an issue in these tunes, and will be taking them down until he gets it squared away. In the meantime, please refrain from using these tunes.
