2009 Tahoe z71 5.3L running rich
Posted: Mon Apr 05, 2010 2:35 pm
by krom
Hey gang,
New to the forum. I am thinking of purchasing a 7194 for my 09 Tahoe Z71 5.3L. I have a Flowmaster Series 50 SUV muffler and Volant CAI. The motor seems to be running rich now due to the CAI. Wondering if one of the tunes on the 7194 or a Diablew tune can help fix this. Thanks for your input.
RE: 2009 Tahoe z71 5.3L running rich
Posted: Mon Apr 05, 2010 3:54 pm
yes, it can be fixed by getting your fueling adjusted correctly...
and can also be fixed and more power gotten via a custom tune...
Posted: Mon Apr 05, 2010 7:47 pm
by krom
Re: 2009 Tahoe z71 5.3L running rich
Posted: Tue Apr 06, 2010 12:37 pm
by redfoxsa
krom wrote:Hey gang,
i have a same setup you have
i have a magnaflow cat back
after i install the volant CIA i feel like i lose some power and the motor seems unstable maybe running rich due to CAI.
i don't know what i have to do .
Regards
RE: Re: 2009 Tahoe z71 5.3L running rich
Posted: Tue Apr 06, 2010 1:18 pm
check the stickies and do some data logging, adjust your slope to get your fueling adjusted correctly so that your average ltft's are in the 0 to -2 range...
Posted: Tue Apr 06, 2010 3:14 pm
by krom
Hi Monte,
In another Q&A thread the member posted:
-- Can I make my own custom tunes (not just a modified tune)?
You said this is possible only if you are a dealer or authorized tuner with the software. I take it the exception is being able to adjust your injector slope so that you can bring the ltft's in range as you specify?
Posted: Tue Apr 06, 2010 4:03 pm
yes... that's considered a "modified tune"... you can modify the tune via the predator/trinity yourself...
a "custom tune" is done via the tuning software...
With the 7194 predator for your vehicle, you can do/adjust all of these things yourself, via the predator unit itself:
COT time delay
DoD disable
Idle RPM Drive/Neutral
Injector Slope adjustment
WOT Fuel 2k-3.8k / 4k-4.9k / 5k-7k
Rev Limit
WOT Spark (in degrees) 1k-3.8k / 4k-5k / 5.2k-7k
Fan adjustment, individual adjustment per temp dependent cell
Tire Size
Speed limit(truck/SUV only)
Clear codes supported
Live data and log supported
Posted: Tue Apr 06, 2010 5:56 pm
by krom
Yes. I found that list on the product page. In addition to that, what is the custom tune able to provide?
Posted: Tue Apr 06, 2010 7:22 pm
a custom tune, done by a diablosport CMR tuner such as myself, adjusts a lot more parameters that the end-user doesn't have available via the predator/trinity handheld unit...
the CMR tuning software is like hp tuners, efi live, etc etc and allows access to EVERYTHING in a tune file...
the fueling and timing adjustments can be done more precisely, instead of just a general range like the handheld has you do...
torque management settings, knock retard settings, throttle settings, WOT/PE settings, AFR settings, fueling, timing, and a whole slew of other things...
Posted: Tue Apr 06, 2010 9:26 pm
by krom
Excellent. Thank you.
