87 octane tune
Posted: Thu Apr 08, 2010 9:58 pm
by 6gear
I just did and 87 octane tune on my 09 Silvy 5.3 so what all does that include? Does it kill my mph limit or set it to a different number? does it kill any torque management, firm up the shift, change max rpm? add any power?
RE: 87 octane tune
Posted: Fri Apr 09, 2010 9:03 am
TM is reduced, timing and fueling are optimized. Adds about 15 rwhp/25 ftlbs
SPeed limiter can be disabled in the adjustable parameters.
RE: 87 octane tune
Posted: Fri Apr 09, 2010 9:06 am
by 6gear
So I need to plug my unit back in to disable the speed limiter? Where will I find this setting?
RE: 87 octane tune
Posted: Fri Apr 09, 2010 9:10 am
after you select the tune go to modify tune, modify parameters and select rev and speed limits. set the limiter to OFF and press ESC until it asks you if you want to reinstall the tune, choose yes.
RE: 87 octane tune
Posted: Fri Apr 09, 2010 10:53 am
by 6gear
THANK YOU
RE: 87 octane tune
Posted: Sat Apr 10, 2010 12:48 am
by pelicandivebomb
how much power is the 87 octane tune supposed to give a 6.0?
