I am unable to turn off both limiters. When I modify the parameters, it should show that both are turned off, and it shows the default setting. I was curious that it has an * beside the setting, it meant that that parameter was modified. When I found an open stretch of road to test the theory. I found out that they have not been turned off.
Any help would be appreciated.
Speed Limiters
RE: Speed Limiters
Make sure that after setting both limiters to off, that you press escape until the tool prompts you to install the tune, and then do so, as this is necessary before any changes can take place.
Speed Limiters
OK - time for a dumb question, shouldn't the predator show that the limiters have been turn off, not just have an * beside showing it has been modified?
RE: Speed Limiters
'ON' is the default setting, so anytime you go in there it will show on, but you have to select it and make a change in order for it to take effect.
Mike
Mike
