Test Mode??
Test Mode??
Still having problems with my Trinity. The tool froze while programming my truck so I had to send it in. Got the Trinity back from you guys and now when I plug it in it says that it is in TEST MODE. The key and touchscreen test pass but OBDII and Analog Fail. When i try to plug the trinity in my computer and update it I am not able to do anything because it is still in test mode. What can i do??
Re: Test Mode??
It was returned to you from rma in test mode?CSMALL wrote:Still having problems with my Trinity. The tool froze while programming my truck so I had to send it in. Got the Trinity back from you guys and now when I plug it in it says that it is in TEST MODE. The key and touchscreen test pass but OBDII and Analog Fail. When i try to plug the trinity in my computer and update it I am not able to do anything because it is still in test mode. What can i do??
What was the rma#?
Re: RE: Test Mode??
Could it possibly be the two buttons that are on the right side of the screen that are vertical?HarrisonZ wrote:How did you get it to pass the key test? When mine did that, I could figure out what the last 2 keys were.
RE: Re: RE: Test Mode??
I was not asked to fill out an RMA form. While programming my truck the module froze and would not recover. I had to send it in in order for them to fix it. Now that I have it back it will not let me get out of test mode or update it online. When i plug it into my truck it fails the OBII test.
Re: RE: Test Mode??
yes...CSMALL wrote:Could it possibly be the two buttons that are on the right side of the screen that are vertical?HarrisonZ wrote:How did you get it to pass the key test? When mine did that, I could figure out what the last 2 keys were.
Re: RE: Re: RE: Test Mode??
so, where did you send it?CSMALL wrote:I was not asked to fill out an RMA form. While programming my truck the module froze and would not recover. I had to send it in in order for them to fix it. Now that I have it back it will not let me get out of test mode or update it online. When i plug it into my truck it fails the OBII test.
who got the rma#?
I want to fix this for you asap, but need to know who sent it in.
RE: Re: RE: Re: RE: Test Mode??
Don't feel dumb. I didn't notice them for months either. They just blend in so well.
The top one is a back button, or they can be used to click either of the two touch screen buttons on the right side of the screen.
