stacker tune for an 05 dodge
I didn't plug in the puck yet. I plug in the predator, go to performance tune and it tells me to turn the ignition on. I turn on the ignition and hit the center button for continue and a (1) comes up on the same screen. If I hit it again it will go to (2) and so on. It will also count if I hit back? Any help would be greatly appreciated. do you think it could have something to do with the box being an 06-07 if my truck is an 05? thanks, russ
- duallydave
well they told me the 7131 is the right one if you buy the stacker kit for an 05? every thing works but it just won't load the performance option. I checked the codes and there are none and I also checked the tune and it is to the original tune? If that is wrong about the 7131 then maybe I should make them give me a 7130 like you said?
