pinging problem on '98 Cobra
I recently purchased a U7146 unit for my '98 Cobra. With the predator tune installed i get pinging at WOT. I have tried retarding the timing and still the problem persists. The car has only minor bolt on mods and i get no pinging with the stock tune. I use 91 octane fuel. Any suggestions?
RE: pinging problem on
You can always go into the adjustable parameters and remove some timing. I would try a different brand of fuel as well. I personally prefer mobil, sunoco or amoco/bp.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
I already tried removing some timing and still had the pinging problem. I also tried octane booster with no better results. Any other ideas?
I would try to remove more timing, what brand fuel do you have in there?
Diablosport INC
Diablosport INC
Check your coil packs, spark plugs and all other ignition related components as well.
I use Arco 91 octane with octane booster. I have tried taking out timing all the way to 40%. The pinging is less noticable as i remove timing but still there at wot. Has brand new plugs and wires. How do i check the coil paks? Very strange that with the stock tune I have no issues. I also have 3.73 gears, magnaflow mufflers and K&N CAI if that has any bearing on the situation. Thank you for your prompt responses.
