'10 challenger rt with manual transmision
aarcuda72032
Post by aarcuda72032 »
How come theres no place to enter stuff for a manual trans. theres only the auto listed under the MODIFY TUNE section but under Options menu , Change Vehicle Type, iot doesnt have anything related to 6sp manual.
I thought there was some way to disable the Skip Shift using the Trinity?????
Do I need to manually adjust for tire size or gear ratio in order to get correct monitoring or anything
RE:
Skip shift is disabled by default when you load the tunes...
aarcuda72032
RE:
hmmmmm, I "thought " i loaded the 93 octane CAI tune but i am still getting the skip shift. Maybe I reloaded the original tune into it???
aarcuda72032
Re: RE:
aarcuda72032 wrote:hmmmmm, I "thought " i loaded the 93 octane CAI tune but i am still getting the skip shift. Maybe I reloaded the original tune into it???
Well I just plugged it in and read that the Last Written was Perf CAI 93oct but i am still getting the ship shift to kick in.... I wonder why?
RE: Re: RE:
What revision?
aarcuda72032
RE: Re: RE:
ok, i screwed up i guess. i tried it last night and made it show the Skip Shift on the EVIC and then shifted to 2nd.
Did it twice to make sure and sure enough, the Skip shift IS disabled so it was all me. But I'll keep an eye on it. I could have sworn I was forced into a skip shift the day but now i cant be so sure I just didnt see the EVIC message and shift to 4th (old habits are hard to break)
aarcuda72032
RE: Re: RE:
well, I guess its randoms cause yesterday i hit the skip shift twice and i havent touched the tune. as for the revision, i cant tell you cause i dont have it in front of me right now but i know I tried to load the 7135a uodate but I had somerouble with it asking me to reload the original tune in my car but every time i tried, it kept telling me to reload the original tune as if it hadnt just done as i requested. this may all be cause by my connector problem i was having
aarcuda72032
RE: Re: RE:
tired it again today. first two times the shift shift light came on I could go into second. the next two times i tried i was forced into fourth...
RE: Re: RE:
This is new...
aarcuda72032
RE: Re: RE:
any updates on the issue. i saw somewhere on challengertalk that you had an update coming to fix this issue. Is that update out yet?
