ESP enable/disable option??
luis_gts
Post by luis_gts »
Hello All,
I just want to know if the trinity is capable to turn off the ESP control?
And also how to set up the shift light???
Luis
RE: ESP enable/disable option??
ESP is reduced in the tunes, and can be disabled in the trinity.
There is a sticky here with info on setting up shift lights, gauge alarms, and more:
To set up a shift light, create a layout or open one of our layouts (in logging) that has an RPM gauge in the display.
Click on the RPM gauge.
Select 'set shift light'.
Set the RPM you would like the shift light to activate, press enter.
You'll now select whether you want one (1) LED, all LEDs, or a progressive shift light.
Now, click record and your shift light will be activated.
If you close the layout, and save it, you can open it in monitoring and your Shift light will be there.
http://www.diablosport.com/index.php?na ... ic&t=15356
HELBOY
Post by HELBOY »
Hello Mike:
Could you please explain how to disabled the ESP with the Trinity?
Regards.
Yuri
Charger Daytona R/T Tor Red 2006.
Trinity T-100
Underdrive Pulley SLP
Down Pipe 3 inch.
Cat Delete 3 Inch.
Cat Back 3 Inch. Magnaflow
CAI MOPAR
enable dyno mode, but that will disable ABS as well so be careful....
HELBOY
Post by HELBOY »
thank´s. i will be careful.
My car has 35,000 kms in the odometer, and i want to change the spark plugs, which brand and model do you recommend?,
Regards.
speedrules1
Post by speedrules1 »
I was wondering if you could setup a tune that would make the esp work when on with the button in the car and go tottally off when switched off in the car?
fordomatic69
Post by fordomatic69 »
For the 5.7L, The NGK Iridium IX is an awesome plug (NGK Part # LZTR4AIX-11). If you have an SRT-8, then it's NGK Iridium IX part number LZTR5AIX-13. Word of warning though, they are flippin' expensive.
Fordomatic Says:
"I've heard of Vaporware... but I've never actually seen it" :lol:
