I installed a 160 degree thermostat in my 05 GTO. Further research requires the fans to turn on different. I checked the Predator but do not have the ability. The settings need to be changed to
FAN 1 ON 184F - OFF 175F and
FAN 2 ON 194F - OFF 185F. I contacted my CMR tuner and he located the following tables:
My tuner was unsure if the fans can be set per temp settings. If Johan wouldnt mind modifying the attached tune to compensate for the lower 160 thermostat it would be appreciated yet again.
