01 7.3 Powerstroke Fuel Economy
Posted: Tue Apr 27, 2010 5:56 pm
by ctravaglino
I have a 2001 Ford F250 - 7.3L and looking for an Economy Tune. I am getting poor fuel mileage on the 85 HP tune.
Predator U7170
Do you guys have anything that will work?
Chris
RE: 01 7.3 Powerstroke Fuel Economy
Posted: Tue Apr 27, 2010 6:34 pm
Have you tried the 100 tune?
Check it out, just keep your foot out of it...
Posted: Wed Apr 28, 2010 1:10 pm
by ctravaglino
So your saying that the 100 tune will be better with fuel then the 85 tune? I would think the opposite, but I'll give it a try.
I will be towing this weekend my 35' 5th wheel and will use the tow tune for the first time. Will the fuel be better then using the stock tune? Will I feel a difference in power while towing on the tow tune?
Chris
Posted: Wed Apr 28, 2010 3:04 pm
Yes, the tow tune should help you get 1-3 MPG better than stock when towing, and makes a solid 40 rwhp and 100 f/lbs at the wheels.
Posted: Tue May 04, 2010 8:01 am
by ctravaglino
Ok..I towed with the Tow Tune this weekend and was only getting 6 MPG! Do you have any idea why that would be? I should be getting 12 or better, I think.
What is the fuel economy that you guys have seen in the past while towing a 10K lb 5th wheel at 65 - 70 MPH?
Posted: Tue May 04, 2010 10:30 am
Clogged fuel filter?
Bad injectors?
Something is not right....
Posted: Tue May 04, 2010 1:11 pm
by ctravaglino
Will the tuner tell me this from the data logging?
Posted: Tue May 04, 2010 1:17 pm
if it shows desired and actual rail pressure you'll be able to see it.
