Page 1 of 3
Incompatible hardware (no serial flash found) error
Posted: Fri Apr 30, 2010 4:09 pm
by NHChalnga
I'm trying to load the u7135-9r23.crom file to my Predator and receive an error stating "Incompatible hardware (no serial flash found) Contact tech support" error as the upload to the Predator completes.
I can successfully load the 9r12 crom so I'm guessing that my Predator does not have enough memory to load the 9r23 file.
My car is a 2009 Challenger SRT8. The calib code is 63004308AG which I'm hoping is supported in 9r23, but I have not found anything to definitively say one way or another.
If 63004308AG is supported, what's the work around for not being able to load the full 9r23 file?
RE: Incompatible hardware (no serial flash found) error
Posted: Fri Apr 30, 2010 4:20 pm
email sent.
Posted: Fri Apr 30, 2010 7:24 pm
by NHChalnga
Thanks for the quick response Mike. It worked perfectly.
Posted: Mon May 03, 2010 3:28 pm
by flo1
Hi Mike,
got a simlar problem with the "unable to store CROM file" appearing on display when trying to update to r23.
r12 workes fine but doesn't support 2010 SRT.
I think i do need the same file as NHChalnga...
BR
Flo
Posted: Mon May 03, 2010 3:36 pm
sent...
Posted: Mon May 03, 2010 3:43 pm
by flo1
Posted: Fri May 07, 2010 6:08 pm
by wilson_gau
I have same problem. I just get a used Predator. After I upload u7135-9r23.crom file, it shows the message "Incompatible hardware. (No serial flash found). Contact tech support (561) 908-0040 x1
www.DiabloSport.com"
Posted: Mon May 10, 2010 10:47 am
email sent
Posted: Mon May 10, 2010 7:42 pm
by wilson_gau
I updated using the file you sent me and it says:
"Predator u7135 does not support
Calid: 05094680AH
Too, update might be available"
Is that normal or I need other file?
Re: RE: Incompatible hardware (no serial flash found) error
Posted: Tue May 11, 2010 11:49 am
wilson_gau wrote:I updated using the file you sent me and it says:
Calid: 05094680AH
what year is your vehicle?
if it is older than09, use 9r12.
Posted: Tue May 11, 2010 11:45 pm
by wilson_gau
mikel wrote:wilson_gau wrote:I updated using the file you sent me and it says:
Calid: 05094680AH
06. Do I need the latest update?
Is the update is the problem or the device? Since before I plug it to my car, the error code already displayed.
RE: Re: RE: Incompatible hardware (no serial flash found) er
Posted: Tue Sep 21, 2010 1:52 am
by gogreen1919
incompatible hardware
same thing but the downloader will not function anymore it had 9r12 i updated to the latest one 9r27 or whatever that one was and got that message now it will not take anyfile and will not recognize in the downloader with or without the auto-detect on
Re: Incompatible hardware (no serial flash found) error
Posted: Wed Sep 22, 2010 7:29 am
by Zog
Same issue, Mike. '09 Challenger R/T.
Thanks in advance!
NHChalnga wrote:I'm trying to load the u7135-9r23.crom file to my Predator and receive an error stating "Incompatible hardware (no serial flash found) Contact tech support" error as the upload to the Predator completes.
RE: Re: Incompatible hardware (no serial flash found) error
Posted: Wed Sep 22, 2010 11:15 am
sent!
Posted: Fri Sep 24, 2010 1:39 am
by HowardCan
Hi Mike, new owner of a Pretador and trying to get it going before the car is put away for the winter.
Similar issue here in that I am trying to install the latest CROM (v.9r27 I believe) as the unit will only accept the r12 CROM.
09 Challenger R/T
