7198- out of memory
musclebound
7198- out of memory
Post by musclebound »
I'm getting the out of memory error and from what i read so far, i need to re-install the stock tune before i can update the controller. i bought the truck with the supercharger and tune already installed. I'm new to this predator thing so here goes a stupid question... how do i back up the current tune if i can't download anything?
musclebound
RE: 7198- out of memory
TTT- anybody???
What revision is on the Predator currently?
musclebound
9R15
musclebound
nobody?
dunno man...
you gotta wait for Mike on this one...
so, when you try to upload a copy of the stock tune ot the PC the predator says out of memory?
musclebound
yeah... i took the truck out and logged some data for awhile and when i hook it up to the pc the predator says out of memory and to re-boot.
I'll have to try this with my U7198...
how long was the log?
musclebound
if i remember right, the log or status on the tuner said something like 70%... i think i drove for a few minutes down the highway
I just uploaded a 10:32 log from my U7198 to the 3.3 version of DV, noprob.
How many PIDs did you record?
have you tried a new log to see if it will upload?
musclebound
Can't remember off hand how many PID's i recorded (only selected a few), but I've tried running different logs- some shorter some longer... with the same result.
ruben6669
Post by ruben6669 »
I had the same problem with my 7198 in trying to get the cruise log data downloaded to my computer. The predator showed "out of memory" the first time, and the second time I had no problems. The difference was that I took a long time to hook up my predator to my computer the first time (4-5 days), and the second time I actually took my laptop with me in the vehicle and everything downloaded the way it should, try it out.
bam99ss
Post by bam99ss »
I had that prob today when loggin. I had to set it back to stock tune then redo the tunning stuff then log again. Then it worked.
musclebound
Haven't had time to mess with the truck, but as was brought up in another thread, use the tuner as a pass thru for the lap top. I don't want to loose the current tune since I really don't know what was done. So I figured if I at least had a baseline of the current tune before i started to delete and modify things, I should be safe.
