2004 GTO - P0141 Error
Posted: Sun May 02, 2010 3:05 pm
by ookoz
Hello, i have a 04 6 speed GTO with CAI and diablo performance tune. I was under the impression the tune would disable these codes from coming on and it did, but it keeps coming back after a few miles of driving.
Ive had a shop look at the sensor and they said everything is fine so I just want to disable the code permanently.
Any help would be appreciated
RE: 2004 GTO - P0141 Error
Posted: Sun May 02, 2010 6:16 pm
by ookoz
I am using U7193 with all the latest updates btw
Posted: Sun May 02, 2010 6:26 pm
by highlife756
Shop said sensor looked ok (wiring) or performed ok? If wiring is ok I'd suspect the sensor is bad.
Posted: Sun May 02, 2010 6:27 pm
by highlife756
Or if you have a different exhaust and moved the o2 sensor that could affect it I think
Posted: Sun May 02, 2010 7:25 pm
by ookoz
i have stock exhaust. they tested the sensor and replaced it just to make sure so its for sure a working sensor. They said they could send and receive info(whatever that means) but I would have to take my car to the pontiac dealership so they can erase the code from my computer
Posted: Mon May 03, 2010 2:11 pm
by highlife756
You cant clear the code with your predator? I also have an 04 GTO 6 speed, and I have the SLP (7199) predator and I can scan and clear DTC's. If they can see the code on their scanner, I'm surprised they cant clear it too.
A code P0141 may mean that one or more of the following has happened:
open or short to ground in the wiring harness
O2 heater circuit wiring high resistance
O2 heater element resistance is high
Internal short or open in the heater element
Posted: Mon May 03, 2010 2:13 pm
by highlife756
Or see if 06montess can hook you up with a tune that will disable it for you
Posted: Mon May 03, 2010 5:52 pm
by ookoz
i can clear it but it comes back after a while randomly. ive heard that its not a big deal and i just want to permanently disable it
Posted: Mon May 03, 2010 6:08 pm
by highlife756
I dunno. Either fix the sensor or get a tune that disables that code.
Posted: Mon May 03, 2010 6:25 pm
If the wiring is fine, it must be a bad sensor/heater element.
