Page 1 of 2
2008 Chevy Silverado gear ratio change
Posted: Tue May 04, 2010 9:58 pm
by seanq
Can I reset the gear ratio using my trinity?
RE: 2008 Chevy Silverado gear ratio change
Posted: Wed May 05, 2010 9:25 am
Not at the moment, but we can do it for you in a custom tune if needed...
Posted: Tue May 25, 2010 8:17 pm
by seanq
Ok I how do I get this custom tune I have not installed my trinity yet. I have a 2008 Chevy Silverado crew cab 5.3 4x4
also when I plug the trinity into my computer is it not acknoledgeing it.
Posted: Wed May 26, 2010 9:17 am
Sounds like you need to install the Trinity Driver from the CD.
Posted: Thu May 27, 2010 11:31 pm
by seanq
I have the trinity working with my PC now. I need a custom tune to adjust dsettings for a gear ration change.
I have a 2008 silverado 5.3ltr I have changed my gears from 3.73 to a 4.56 gear ratio. Can you please send me a custom tune. I have not installed my trinity yet do to waiting for this tune.
Posted: Fri May 28, 2010 7:59 am
by 06MonteSS
you have to install a tune from the trinity, so that the trinity saves the copy of the original backup tune file to it...
then you need to use the latest version of the DSDownloader app (2.2.1.7.) and export the copy of your original backup stock tune file, and also a copy of the "last tune written" tune file...
then post up those two tune files...
Posted: Sat May 29, 2010 12:18 am
by seanq
Ok so I need to tune the truck first then paste a back up on here?
Posted: Sat May 29, 2010 9:55 am
by 06MonteSS
yep
Posted: Mon May 31, 2010 8:14 pm
by seanq
Ok I have programed my truck, I have down loaded the stock tune, I am unable to cut and paste it though or copy and paste. How to I get the file on here. Also I need help with the speedo settings, I have 35 x 12.5 x 20 tire size I do not know this equates to in mm though or aspect ratio please help. I tried setting by tire size but it did not help. Im not sure if this is contribuyed by the gearing change.
Posted: Tue Jun 01, 2010 8:41 am
by 06MonteSS
click the "post reply" button at the bottom left of this page.. .then you'll have a section where you can add the file as an attachment to your post...
chevy siverado gear ratio change
Posted: Tue Jun 01, 2010 9:01 pm
by seanq
6ju279f
2008 chevy silverado 5.3
RE: chevy siverado gear ratio change
Posted: Tue Jun 01, 2010 9:02 pm
by seanq
ok I think that will do it, please advise on tire adjustment from post 05/31/10
Posted: Wed Jun 16, 2010 7:16 pm
by seanq
Ok are you guys working on this, I only bought your tuner because you said you could do a custom tune for the gear ratio. I am no longer getting responces from you. I would really like to get my spedo right as it is racking up extra miles on my truck and effecting the over all milage.
Posted: Thu Jun 17, 2010 9:34 am
sorry...we'll need a copy of the last tune written to the truck as well please.
Posted: Thu Jun 17, 2010 4:35 pm
by seanq
Ok how do I get that I used your standard tune with out changing any parameters. Also back to the tires I need to know the correct formula for inputing for a 35, 12.5, 20.
