Reading Fuel pressure
Posted: Wed May 05, 2010 1:19 pm
by fixmedaily
Help please:
Is there a PID for reading the Fuel pressure comming into the cp3 pump?
I have installed a AirDog lift pump and do not know what fuel pressure it is putting out. My Glowshift gauge is pegged at max and I do not believe it is working properly. Need to read the input fuel pressure from my trinity.
Re: Reading Fuel pressure
Posted: Wed May 05, 2010 1:28 pm
by Speardog
fixmedaily wrote:Help please:
I would like to know the same thing to so I don't have to get a fuel pressure gauge. I know that the Quadzilla Adrenaline (according to their website) is able to read normal fuel pressure sustained by the lift pump, but I don't know what signal it is picking up. There has to be a PID, I just don't know which one.
Jeff
RE: Re: Reading Fuel pressure
Posted: Wed May 05, 2010 8:41 pm
by CumminsDemon
I believe the PID for HFP is the HPCR.....reads in MPa. 168MPa=27k PSI
Re: RE: Re: Reading Fuel pressure
Posted: Fri May 07, 2010 12:34 am
by Speardog
CumminsDemon wrote:I believe the PID for HFP is the HPCR.....reads in MPa. 168MPa=27k PSI
ithere is a "fuel pressure" pid that reads up to 27k. But that is rail pressure, not fuel pressure
Posted: Sun May 09, 2010 6:44 pm
by CumminsDemon
ithere is a "fuel pressure" pid that reads up to 27k. But that is rail pressure, not fuel pressure[/quote]
Oh hes woundering about the low pressure fuel pump.....gott cha.
Posted: Wed May 19, 2010 1:24 pm
by 3-DRacing
Same thing I've been trying to figure out. Mine is a early 04 that had the lift pump on the fuel filter canister and was replaced under warranty with a in the tank pump, curious what it puts out. Would be nice to have the rail pressure read psi too.
Posted: Wed May 19, 2010 2:13 pm
if rail pressure reads in kpa, click on it in the logging menu, choose change display units, choose PSI, then save the layout.
Posted: Wed Apr 06, 2011 7:47 pm
by danny3535
mikel wrote:if rail pressure reads in kpa, click on it in the logging menu, choose change display units, choose PSI, then save the layout.
You mean mpa.
That the rail pressure is read in factory and you cannot change it to psi! I tried and it said that wasn't any other options. It would be great to have in psi so you don't have to multiply your mpa reading by 145 every time.
Posted: Thu Apr 07, 2011 9:45 am
correct.
Problem with displaying it in psi is the values are too large to fit onthe gauges...
Posted: Sat Apr 23, 2011 2:20 pm
by Speardog
danny3535 wrote:mikel wrote:if rail pressure reads in kpa, click on it in the logging menu, choose change display units, choose PSI, then save the layout.
You mean mpa.
Not sure if your truck is different, but mine reads rail pressure in psi. It was under the HPCR fuel pressure PID.
