Boost Fooling
lpennock
Boost Fooling
Post by lpennock »
Are you looking at adding adjustable Boost fooling to U7131. Since the waste gate is controlled by the computer seems you should be able to turn up the boost. BTW: The smarty does boost fooling I believe.
Leonard Pennock
AD7AS
2006 Mustang GT
2006 Dodge Ram 3500 Diesel
RRAM
RE: Boost Fooling
Post by RRAM »
you can add a boost fooler for like 70 bucks. I find I hate the thing as I get a so much turbo bark. I do run it when towing as it seems to help a bit with egts.
Reg
2005 3500 Quad Cab Laramie L/B
Predator, AFE stage II, boost fooler
Pillar Mount gauges Billet low stall TC
lpennock
RE: Boost Fooling
Post by lpennock »
The boost fooler effectively shuts off the waste gate. If the predator was to do it they should be able to allow you to chose a boost point. Probably not that big of a difference with a stock turbo but if you go to an after market turbo without studs could be a big difference.
Leonard Pennock
AD7AS
2006 Mustang GT
