Page 1 of 2
New rail pressure/timing adjust update available! 2010 added
Posted: Tue May 11, 2010 6:05 pm
I have a new update available for the U7186.
http://www.diablosport.com/ascripts/fdo ... name=mikel
This new update, in addition to adding support for 2010 applications, has 2 new adjustable parameters for Fuel Rail Pressure adjustment and Injector Timing adjustment.
Timing can be added or removed in .5* increments, while pressure can be raised or lowered in 100 kpa increments.
Enjoy!
RE: New rail pressure/timing adjust update available! 2010 a
Posted: Sun Aug 01, 2010 12:34 pm
by Trotorx2
What benefits will this provide, I know nothing about tuning a diesel, so how will I know if these adjustments will help?
Also what other changes were made to this update? I cant fine tune my tire height with the ver. 08 that I have now.
2007 duramax U7186 adjusting fuel rail pressure and timing
Posted: Mon Aug 02, 2010 8:31 pm
by hromadka_jay
I have the U7186 rev 9r11 installed in a 2007 lbz duramax.
I was wondering what is a good setting to use on the fuel rail pressure at WOT and Injector timing. I have no clue what to set it on and what benefits I should get from these two settings.
RE: 2007 duramax U7186 adjusting fuel rail pressure and timi
Posted: Tue Aug 03, 2010 9:44 am
To be honest, if your not sure, leave them alone.
We have optimized the settings in the tunes already, these adjustments are for end users that are looking for a way to stack pressure or timing boxes, and need a more advanced tuning option.
2007 duramax poo87 fuel rail pressure low
Posted: Tue Aug 03, 2010 1:07 pm
by hromadka_jay
I am having trouble with my u7186 when set on 120hp at wide open throttle I get a check engine light and my truck goes into limp mode. I get the code P0087 which is fuel rail pressure low. What is causing this? When I have it on 85hp it runs great almost better than the 120 hp and shifts smoother with no check engine light. Help?
RE: 2007 duramax poo87 fuel rail pressure low
Posted: Tue Aug 03, 2010 1:50 pm
Sounds like the fuel pump is not keeping up with the commanded fuel pressure in the 120 tune.
Most likely cause would be a clogged fuel filter.
2007 duramax lbz
Posted: Tue Aug 03, 2010 8:59 pm
by hromadka_jay
Do I need a lift pump or a FPRV shim kit to get the full effect of the 120hp tune? I have 2 friends that have the same truck and the same predator. They both have the same issues on the 120 tune. We all have to let off of the throttle to allow the truck to shift to the next gear or the P0087 will come up and go into limp mode.
RE: 2007 duramax lbz
Posted: Wed Aug 04, 2010 12:27 pm
Are all of these trucks running the same revision?
It is just odd since we have not changed these tunes in 3 or 4 years and I have never seen this issue before.
2007 duramax lbz
Posted: Wed Aug 04, 2010 11:28 pm
by hromadka_jay
Yes, all of our trucks have the same revision, the latest one. So what is the fix? Lift pump?
Posted: Thu Aug 05, 2010 9:46 am
I want to investigate a bit....this has never been an issue in the past with these tunes.
2007 duramax lbz
Posted: Thu Aug 05, 2010 1:12 pm
by hromadka_jay
Well please let me know what you find out. Thanks!
Posted: Thu Aug 05, 2010 5:51 pm
by bigdawg04
Thought I would try the 120 hp setting on my 2007 LBZ, well had same results as listed above , put back to 85hp and all is fine
Posted: Thu Aug 05, 2010 6:15 pm
Ugggh, I gotta see what changed.
Can you guys write the tune, export last tune written, and then post it up?
2007 lbz duramax
Posted: Thu Aug 05, 2010 11:47 pm
by hromadka_jay
I have solved the problem! I ordered a fuel pressure relief valve shim kit and installed it today and the truck drives awesome. No problems shifting and no more check engine light. I is just bad to the bone! I guess the relief valve was dumping fuel back to the tank too soon creating a problem. Shimming the valve increased the fuel pressure and made the truck perform like it should on the 120 hp setting.
RE: 2007 lbz duramax
Posted: Fri Aug 06, 2010 8:46 am
Wow, that is interesting.
What all was in that kit?
I think the kits we have with the EPPs are just 3 #4 SAE washers...
