dialing in a/f
crazyhorse
dialing in a/f
Post by crazyhorse »
can i dial in my a/f? i have a 4.8 silverado 2003 with j.b.a wires outlaw cai dual cat back system. amsoil oil and grease frt. and rear diffs,also in trans. i have the 93 oct . tune from my predator #7195 installed.also amsoil in the engine and it's a 4x4.Thanks yous guys.Happy 4th.
RE: dialing in a/f
take a look at the stickies at the top of the forum for getting your fueling dialed in...
crazyhorse
RE: dialing in a/f
i have another question,i've noticed that when i engage the live data that #7195 will show live data and it will hang in a live data mode. example i'll be cruisein at 60 mph and the live log data screen will be reading that i'm at idle .every time i make adj. i disengage the unit before i shut the engine down .whats goin on? i pay close attention to the instructions. the only way to clear the screen at that time is to disengage from the dash. i can't clear the screen or take it to the menu. it has just started this today. i don't start her up till i disengage when i do make adj.again whats goin on?
RE: dialing in a/f
not sure what's going on there - that's a new one to me, haven't heard of that happening before...
I'll give this a bump by this reply and Mike should be chiming in...
crazyhorse
RE: dialing in a/f
thanks, like i tried to explain i 'll be tachin 1700 on the dash look down at the live data screen and it will at 680 and will stay there untill i disengage from the comp. port. can't scroll back change screens or nothin. See Ya Jim
RE: dialing in a/f
Sounds like the tool may be freezing up.
Maybe you should consider sending it in under an RMA for a checkup.
