lambda?
BorlaGTO
lambda?
Post by BorlaGTO »
05 GTO M6
What is the best lambda to have at WOT? With the diablo tune at WOT i get between 1.08 and 1.23 monitoring it on the trinity
Mods are as follows.
cat-back exhaust
CAI
Manifold
160 stat
wires
RE: lambda?
don't go by that... it does the same thing for 06 gto's, and 06 Monte SS, 06 Impala SS, etc etc. on the screen.. the values are inverted...
you need to download the data log with the dataviewer.... and then in the dataviewer, go to View - Parameter Modifiers - Equivalence Ratio Invert... then it will show the correct AFR value in the data log...
then, go to File - Export to CSV.... and save it as a csv file to your PC...
then you can open up that csv file in MS Excel and see what the values actually are...
or, just post up the .log file, and I can take a quick look at it for ya and letcha know what's what...
BorlaGTO
Post by BorlaGTO »
OK just got done doin this(i think i did it right) and i got an afr of 18.09 peak at WOT! even after i did the inverted. Here is my log, i did it with the "gm gas 6k shift" that was preloaded on the trinity. If this is really what i am getting can someone give me some advice on how to fix?
no, you didn't do it correctly... here, I've attached the files for ya...
oh, and for logging, you can use the DS Log Redux preset to log the needed parameters for using the dslogredux app with...
Return to “Trinity GM Gas”
