Trouble Code
Posted: Sat May 15, 2010 5:22 pm
by Popfly
I do you go about clearing trouble codes from the ECM?
RE: Trouble Code
Posted: Sat May 15, 2010 5:31 pm
clearing trouble codes, or getting them disabled??
clearing them, you just use the predator to scan for trouble codes.. and if there are any that show up, there's an option on there to clear them... select that option...
but if you're talking about disabling trouble codes so they don't come back on at all due to mods you've done to your car, well - you can't... that functionality was removed a few years ago, due to EPA regulations...
you'll need to get a custom tune created by a diablosport CMR tuner (like myself) in order to have the codes disabled in a tune file that you would then import to your predator and then install to your car.
you need to have the usb/serial cable and power adapter for the predator, so that you can connect it to your Windows PC in order to import/export tune files.
and you'll need to download and install the DSDownloader program...
then you'll need to export your original backup stock tune file, and also a copy of the "last tune written" tune file (which is a copy of the diablo tune you have installed in your car)...
then you need to contact a diablo CMR tuner, send 'em those tune files, and pay 'em for a custom tune to disable the necessary trouble codes...
Posted: Sat May 15, 2010 7:45 pm
by Popfly
I did the scan and pulled two codes, P0171 & P0174 their both lean codes for Bank 1&2. I just wanted to clear them until I get in touch with the shop.
I tried the clear button but the Predator could not or would not clear them.
Posted: Mon May 17, 2010 10:41 am
Was the engine turned off?
Posted: Mon May 17, 2010 9:18 pm
by Popfly
Yes, engine was off. I had a custom tune installed last weekend by Diablosport cert. tuner at the shop here in town.
Posted: Mon May 17, 2010 9:23 pm
by Ill_Born_SS
The engine has to be off but the key has to be in the ON position to clear the codes.
Posted: Wed May 19, 2010 6:29 am
by Popfly
The 2008 Corvette has a key Pod, I had it in the accessories mode, is that the correct setup? Also if I was able to read the codes, then I should also be able to clear them I think.
