Ford Lightning shift issues with overdrive button on
robbydiesel
Post by robbydiesel »
this is a u7000 tuner #158 for a 99 Ford Lightning. truck runs fine and shifts fine with overdrive button OFF. when you turn overdrive ON, it shifts too soon and then kicks down like it is confused at wot. it does this on the canned tunes as well as the custom tune. it never did this with my previous Diablo chip. what would the overdrive button have to do with this shifting issue? thanks.
RE: Ford Lightning shift issues with overdrive button on
what is the revision of the Predator?
Can you also post the calibration ID too please?
robbydiesel
hey Mike. the revision is 9r01 and the calibration id is cux1. this is weird because it doesnt do it stock or with my chip. only with the predator on any tune. thanks for your help.
Please go to options/troubleshooting/show calid and tell me what it shows...
robbydiesel
mrad2k3 is the cal id. i have also pinpointed the problem to the part throttle shifting firmness adjustment in the modify parameters section. if i leave the setting stock, all is good. if i try to firm it up any, transmission goes crazy with the od button on. what would cause this? too much pressure maybe. thanks.
robbydiesel
Any ideas?
kmac1
Post by kmac1 »
robby, do you have the cables to export files? If you could export a copy of the file with issues I can take a look at it.
Kevin MacDonald
Calibration
www.jpcracing.com
For DiabloSport Tech Support: [email protected]
robbydiesel
hey, here is a copy of the custom tune that i run. it also has this shifting issue on the diablo canned tunes as well. like i said, it runs great as long as part throttle shift pressure is not raised.
could a line mod valve cause this?
cux1srjones.frg
jlp custom tune
(224.13 KiB) Downloaded 316 times
robbydiesel
Bump to top.
kmac1
Post by kmac1 »
Do you have a 3.73 in the truck? That is what was in that tune. I left it in there but made a few tweaks, give it a shot...
cux1srjones_diablo.frg
(224.13 KiB) Downloaded 283 times
Kevin MacDonald
Calibration
www.jpcracing.com
robbydiesel
Thanks Kevin, I actually have a 4.10 but I did see that it was set for 3.73 which I corrected in the parameters. I will shoot you a e mail and ask a few questions if that is ok. Thanks.
Return to “Predator Ford Gas”
