05 gt air raid tune problem
Posted: Thu May 27, 2010 6:37 pm
by rabbit79
i have a 05 gt with a air raid cold air intake and when i install the tune for the air raid it has a very rough idle when i start it then i will sputter and die plz help
RE: 05 gt air raid tune problem
Posted: Fri May 28, 2010 8:06 am
Have you removed the venturi from the intake?
Posted: Fri May 28, 2010 8:43 am
by rabbit79
i am sorry what is that?
Posted: Fri May 28, 2010 8:44 am
the airaid intake has a insert that needs to be removed for use with the tune.
Posted: Fri May 28, 2010 1:28 pm
by rabbit79
can u point me in the right direction where this is located and what i would look like? i have never even heard of this part that would have to be removed
Posted: Fri May 28, 2010 2:16 pm
It is referred to as I think the MVT insert or something along those lines, and would be located before the MAF.
Posted: Fri May 28, 2010 3:13 pm
by rabbit79
ok i will see if i can locate this and will let u know thanks for all ur help mike
Posted: Fri May 28, 2010 3:14 pm
by rabbit79
one more question...so this insert do i just take it out? or do i have to buy something else to go in its place?
Posted: Fri May 28, 2010 7:55 pm
by rabbit79
mike i figured it out..u take out the MAF and it slips out thanks again for all the help..going to take it to the track tonight to see how it does
Posted: Tue Jun 01, 2010 11:04 am
It should be a whole new animal!
Posted: Sat Jun 05, 2010 12:42 am
by jrogers
i also have an airaid on a 05gt is there a spasific tune for the airaid if so were can i get it
Posted: Sat Jun 05, 2010 7:15 pm
by rabbit79
what octane do u run in your gt ?
Posted: Sun Jun 06, 2010 2:38 pm
by jrogers
91 octain
Posted: Mon Jun 07, 2010 5:58 pm
by rabbit79
u would run the regular airaid tune with 91 ocatane i run 93+ octane so i use the 93 octane with agressive shifts
