I just received my Trinity today and attempting to update it. However there are several updates listed on the support page, which one do I choose?
My current version is v.1r07 and I'll be using it to tune a 2010 Camaro SS with the LS3 engine and 6 speed manual transmission.
Thanks for your help!
Which Update to Install
RE: Which Update to Install
You dont need anything, you are good to go!
Re: RE: Which Update to Install
Thanks Mike. What's strange is that when I setup the trinity I select 2010 Camaro 6.2L engine, then a message appears on the Trinity screen sayingmikel wrote:You dont need anything, you are good to go!
"This application supports:"
"Chevrolet Corvette C6, 2006-2007 LS2 gas"
"Chevrolet Corvette C6, 2008-2009 LS3 gas"
"Chevrolet Corvet"
No where is 2010 Camaro listed, which is why I thought I needed an update.
RE: Re: RE: Which Update to Install
nah... you're fine... that listing isn't complete...
doesn't have my Monte SS listed either.. but it is supported...
after you select your car, check under options > show information and see if the revision/update is 1r07a
Re: RE: Re: RE: Which Update to Install
Yep, that's the revision. Thanks!06MonteSS wrote:nah... you're fine... that listing isn't complete...
