Calling Johan
dieselram_04
Calling Johan
I have a 2003 dodge ram with a cummins htt 64/13ss turbo afe intake stock injectors and stock pump and i just ordered a diablosport predator. i also run a edge juice with attitude and was wondering if i could run the rkl extreme tune with less timing on top of my edge? I need my truck to run really strong but also keep my egts in check. Not breaking anything is also a concern BTW i have a HTS race tranny so thats not a problem
dieselram_04
Well I have tried the RKL with less timing and my TST turned off and my pyro will still wrap under WOT I was only runing about 36-40 PSI boost because my 62/13ss was set to 32PSI from the factory. I have a boost elbow, but I don't like the way it works. My guess is you will not be able to turn the Edge up that much.
I'm still trying to figure out what settings on TST and program on the Predator work best. I want something with the bottom end of the Diablo, but top end of TST twins and some adjustment room down for when I'm towing.
Lee
2005 CTD 3500 SLT 4x4 QCSB, Patriot Blue / Silver, aFe Stage2, MBRP Exhaust, HTT 62/13SS, Diablo Predator & TST Stacked, Isspro guages, Full DTT 48RE w/ Billet Flex, Input & Output
Lee
