which selection for performance tune for AFE CAI?
steve_ashcroft
I have an 08 mustang 4.6l v-8 that i have a U7145 tuner v.9r03. I have added an AFE CAI. I do not see that make/model as an option when adding the option of a CAI. Which one would i select for an AFE CAI?
RE: which selection for performance tune for AFE CAI?
If the cold air kit you have on your vehicle is not supported then you will need to purchase a custom tune. You can contact us via the link in the signature below and we can help.
http://www.tpctuning.com
steve_ashcroft
Thanks for the info but is it ok to select one of the other availble options of CAI on the tuner to achieve the same results.Just wondering but in regards to CAI and what their function is are they not all similar in function and results? for example just selecting the Airraid option on my tuner???
Yes can somebody give a real good explanation or a webpage where we can read about the difference besides the shape of all
the CAI in the market (the ingenier behind it) ,
Each intake has its own specific airflow. If you load the wrong intake calibration, the car will be either lean or rich and obviously not optimized. The calibrations on the newer vehicles are all airflow based, when airflow changes, the computer has to be "told" is was changed, and what it was changed to. If it is not correct, poor idle/driveability/performance and engine "failsafe" mode are just a few examples of what can and most likely will happen.
Good detailed answer. This is exactly what we need to see more of in this forum...(thanks Mike W.)
Yes thanks for that Info, so now Im in a problem because a buy a CAI without brand from ebay but it has the shape of a AEM CAI,
what can I do in my case to have the right setup ?
You can see the picture in ebay here is the link
http://cgi.ebay.com/ebaymotors/05-06-07 ... ccessories
I have a mustang V6 manual trans and is 2008
Diablosport U7145 revision 9r03
Im using the K&N 91 oct CAI with global sprk +2 degrees (im using 93 oct) and MAF +7
steve_ashcroft
Thanks Tuningss for the info.When will the tuningsuperstore website be up so can get info on purchasing a custome tune ect as i am also considering exhaust mods ie: catted x-pipe and short headers so i am assuming would be needed or a good idea to have a custom tune for those mod's as well.Is it neccesary to make adjustment for change in tire size also or is that more centered towards the BCM than the PCM.
Email us for now in the link below in the signature.
